Yokomo  YZ-2T 2WD ST truck >
Like Tree170Likes
    Hide Wikipost
Old 11-05-2018, 08:42 AM   -   Wikipost
R/C Tech ForumsThread Wiki: Yokomo YZ-2T 2WD ST truck
Last edit by: Cain
Yokomo YZ-2T details to include setup
3 Pad Slipper Conversion Parts needed:
  • YOKS4-303OP Slipper Outer Plate
  • YOKS4-303P1 Slipper Pate Disc Plate
  • YOKB2-670C Slipper Pad (need 1 of these)
Stock Spring Measured Rating (By Neal Lewis)
  • Front: 7.17 n/cm 4.10 lb/in 54.5mm length
  • Rear: 3.77 n/cm 2.15 lb/in 72mm length
Print Wikipost
Old 09-19-2018, 07:46 AM
1/8 IC Fan's Avatar
Trader Rating: 102 (100%+)
Default Yokomo YZ-2T 2WD ST truck
Yokomo YZ-2T 2WD Racing Truck kit -NeoBuggy.net ? Offroad RC Car News
Cain, littlevette and mes like this.
1/8 IC Fan is offline
Old 09-19-2018, 08:07 AM
Tech Legend
Cain's Avatar
Trader Rating: 294 (100%+)
wondering if the new split diff will make its way into the buggy versions. Any idea on what offset of wheels work?
Cain is offline
Old 09-19-2018, 08:23 AM
1/8 IC Fan's Avatar
Not sure, I was trying to find it on Yokomos website, but its not even on it yet.
Old 09-19-2018, 10:14 AM
mes
More information can be found on Mibosport. It uses AE style wheels, e.g. the JConcepts Mono. I am positive there will be an updated version of the buggy with the new transmission in spring at the latest. Their updated 2WD have been released in April the last few years.
Cain likes this.
mes is offline
Old 09-19-2018, 10:29 AM
Tech Legend
Cain's Avatar
Looks like mibo is doing an offer where you also get a gear diff too. I am hopeful that amain could do something like that as it can put some value into the kit versus the likes of xrays xt2 offering that is like 2 trucks in one.
Update: Amain mentioned they don't do those kind of deal matching (for the gear diff). sounds like it would need to come from Yokomo USA to include that as well as its a Yokomo Europe kind of thing. Be nice if they could do that.
How close in general is the price mibo has to the conversion to what amain usually charges?
Cain is offline
Old 09-19-2018, 11:01 AM
MOmo's Avatar
I used a prev. conversion by FactoryWorks using AE/JCo wheels with success.
Should be interesting throwing another ST info the mix.
Losi, AE, Xray and now Yokomo.
MOmo
MOmo is offline
Old 09-19-2018, 11:28 AM
mes
MOmo
...and Schumacher are contemplating to do one, too.
Big_Show likes this.
mes is offline
Old 09-19-2018, 11:40 AM
1/8 IC Fan's Avatar
Id love to see what Jorn is running and if Gerd has any hand in it? Would be awesome too!
Old 09-19-2018, 12:25 PM
mes
Gerd is no longer working in the RC industry. Jörn and Michal used T6.1s at EOS Rd1 last weekend, and Muz Schumacher today confirmed they were thinking about making their own truck.
mes is offline
Old 09-19-2018, 09:47 PM
mes
Thanks once more to Arn0!
http://site.petitrc.com/setup/yokomo/setupyz2t/YZ2T/
mes is offline
Old 09-20-2018, 08:53 AM
mes
Layback = LD (laydown dirt)
More information from Yokomo's website:
Based on the design from our current World Champion YZ-2 platform, the YZ-2T will be a great addition to our already successful line of off-road vehicles!
■RWD Racing Truck
■LD (Laydown Dirt) 3-Gear Transmission Improves Stability
■Easily Accessible 3 Split-Type Gear Box
■Long & Big Bore SLF Shock Fits for Racing Truck
■New Shock Mounting Adjustments For New Front & Rear Suspension Arms
■New Molded Steering Bell Crank & Servo Horn
■New Molded Battery Holder & Electronics Tray
■Ball Differential Included
■New Diff Height Adjustment Cam (0, 1mm, 2mm, 3mm)
■J Concept F2 Body Included
mes is offline
Old 09-20-2018, 10:53 AM
Tech Legend
Cain's Avatar
what are peoples opinions on the slipper pad setup they are using the truck?
Cain is offline
Old 09-20-2018, 12:03 PM
mes
As I was happy that Schelle finally came out with a dedicated Yokomo Nova slipper clutch, I've got one waiting here for the kit to arrive. The standard slipper set-up will be ok and, like any other, can be improved with a set of FR4 pads, e.g. by RDRP or McKune.
mes is offline
Old 09-20-2018, 06:11 PM
Tech Legend
Cain's Avatar
yeah I got a set of FR4 or similar style pads here for the schelle setup actually. I am curious still want exactly is the difference between a schelle and avid setup. I see one is slightly cheaper but with less pads.
Cain is offline
Old 09-20-2018, 07:25 PM
It's just the standard single slipper from the YZ2-DMT. I will probably run the dual slipper like I do with the DMT2, and YZ4SF. With the ventilated top plate though.
stuffandthat is offline
